Estima 2007 2.4 petrol Import No cruise control !!
Anybody know if I can fit/install cruise control to my model which is ACR50 model
TIA
PS My steering wheel has no buttons so no idea if pre wired or not
AFAIK there are no stearing wheel buttons for cruise control, they are on a separate stalk under the headlight stalk right hand side.
I did read on this forum a while back that a chap bought a second hand cruise stalk and connected it and gained cruise control. Have a search on the forum.
It's very hit-and-miss on early cars
Part number for the stalk is 84532-34011
If you have an Areas model, it uses a different steering wheel to the high spec models
No audio control usually means it doesn't have the correct Clockspring (aka spiral cable)
Best bet the to remove the lower steering column and look at the plug if it only has 1 wire it does not have CC wired
if it has multiple wires like in this pic it is wired for audio controls and CC
Sorry i meant the multifunction audio buttons on steering, mine has nothing
can you post a pic of your steering wheel, you may also need to change the clockspring aka spiral cable to suit
