Could you elaborate?
Hi Ian,
Has this just happened or is it since the clocks went back. Have you tried settings to change clock time,when did you last update the software.:huh:
you have to manually change it if is not setup to do it automatically
The time on my head unit was different from the time on the dashboard.  The dashboard clock, I had to change manually for the clocks going back.
