Hello all,
Can anyone verify if the toyota voxy has an inbuilt standard warning buzzer if the headlights are left on, when the car is not in use or before exiting the vehicle?
I had a corolla that did. And other cars too.
However the voxy doesn't. For some reason when the Ignition (push start button is off, no orange led, there's no dash illumination, nor any buzzer sounds.  When headlights stalk is switched on, sidelights or main or lower front fog on.
Which annoyingly drains the Battery, unable to start it!
Dash headlight illumination only comes on when engine running, which is odd.
There must be someone out there who has a voxy or noah who can tell me.
I've checked the fusebox(s) location and layout;
https://toyota-club.net/files/techdata/fuse/noah_70.htm
Nothing labelled.
Thanks for reading.
