Toyota Celica SR indicator and over revving
Logan7460
Hi I’m having a issue with my Toyota it was running fine after mot then on the way home I stopped at a roundabout and the engine cut out so started it up again and just went straight too off again and wouldn’t idle or stay on unless I kept it over 1000rpm when I was driving I did notice that when I put my foot down it was over revving so had to build speed also my hazards are working but not my indicators lights are working too can anyone help
My 5th Generation Celica (yours is 6th Gen') has one fuse for the indicators and another for the hazard lights, so try checking the drivers kick panel - inside near the accelerator - for a blown fuse. The owner's manual that came with the car will show you exactly where it is.
If the car is over revving, but the speed isn't increasing, that is probably your clutch slipping.
