help, i need a picture of the sensor plug 1zz-fe
spajuu
I need a photo of the wires of the shaft position sensor plug in celica 1zz-fe. I mean a picture of what colors go into the plug from this sensor toyota celica 1zz-fe. Thank you for your help in advance.
Personally I cut a small amount of the sleeved plastic away with engine off unclip plug use a ohm meter on its lowest range test pins one at a time other wire to a pin that you pushed through the plastic covering the wire.
You only have two wires lets hope one is still attached to the plug it looks that way in the photo.
its a 2 pin sensor, so a piezo sensor - toyota use white/black for ground
