My Toyota App
Downloaded the App, It showed me my trips on the first day of activation, now nothing!  It says all the doors etc are locked today, but it didn't notify me when the dash cam fell off at 02:20 and set the alarm off! Are there issues with the APP or am I doing something wrong?
Cheers Paul
It sounds like your account is no longer registered to the app? Do you see your details, go to the account in the app and check that it’s you there and says your logged in? If you are then there should be an option to log. You my need to then log  back in again.
11 minutes ago, ernieb said:
It sounds like your account is no longer registered to the app? Do you see your details, go to the account in the app and check that it’s you there and says your logged in? If you are then there should be an option to log. You my need to then log and and back in again.
I have logged out and back in and that worked, thank you P
