condensation inside our toyota..what am i doing wrong
Giraffe76
13 hours ago, anchorman said:
ax, stop quoting the internet, the place where an itchy toe means you’ve definitely got cancer .  🤪
Hows about stop trying to tell everyone else who disagrees with you they are  wrong and you are right the lubricant is there for a reason  the reason being it lubricates parts that would fail if it was not there this includes seals in the pipework and compressor!
I think you should put a W at the front of your username it would be more fitting  🤪
On 11/16/2023 at 5:39 PM, Max_Headroom said:
I have a 2019 and have no condensation issues other than what you would expect in this awful weather (damp clothes etc) have you tried feeling the carpets to see if they are wet and also you check the spare wheel well for standing water as some owners have reported water ingress through the rear light cluster seals, apparently an easy fix.
Thanks for your reply. Nothing is wet or has water in it
