Install Software Toyota Yaris 2017 1.5 HEV CVT
ferbricos
Hello I have a toyota in Portugal and i need reinstall the panel software.
Where can i get the software and instruccions?
Reinstall or update, does the unit boot ?
What is your current version (settings - General - System information) ? It should start with XE or HE,
Do you have sat nav?
Hello, thank for your answer.
Doesnt boot. The scroll bar dont go until the end.
I dont know the version.
Dont have sat nav.
It can not be reinstalled, a boot loop or failed boot is usually a sign of failing memory or a jump start gone wrong - replace the unit, 100-150 euros used
Hello, ive bought a new one MODEL 86140-0D320.
But this one has GPS and my old one doesnt have GPS.
Where can i get cables to connect the GPS of this one?
Thanks.
4 hours ago, flash22 said:
It uses an SMB connector in a Toyota connector housing
Hello, this connector is for antena or to connect to the radio?
That is the GPS plug that goes to the Nav module
if you just have the touch2 (DA) without Nav you do not a GPS socket
