2013 Yaris Hybrid rear washer
TDG
Pump not running. Checked fuse ok. Presume could be a connection probelm or pump failure  so how difficult is it to access? Do I have to remove the engine and offside front wing to reach it ?!!
Wing and engine removal No !!!!, do the front washers work ?
You can access the pump by removing the wheel arch liner
My first step would be to open the tailgate, in the centre there is a hose that plugs into a rubber mount. unplug this and see if the washers work by twisting the wiper stalk for the rear, it does not wash with wiper or when you use the fronts either
Yes I see Bob. Too cold and wet in North Devon to be grovelling around on the drive at the mo!
