I am going to tell you what has been said by others. Making claims like "Toyota-Lift Your Game" will only be seen by forum members. TOC is not affiliated in any way to Toyota the car manufacturer. If you want to get your message across to Toyota you need to contact them via your importer .
Obviously, you are not the only one to suffer this Battery issue over the last 12 months, as you know. But it would be better if everyone was coordinated and at a set time on a set day you all contact Toyota direct, flood them out with the same message and they may "get the message" that lots of their customers are not happy.
  • Like 4
It does seem to be a combination of the Smart entry system and also people not using the cars enough. I have noticed with Toyota vehicles, esp. the more efficient ones like the old diesels and the hybrids, that they expect to be used regularly. When they aren't, that's when they tend to develop issues, and not just the Battery draining!
It is surprising to me that it is still an issue tho', given how long this 12v drain has been a problem in their older cars.
  • Like 3
What market are you in (AU ?) as the Yaris cross wasn't released till late 2020, why are there 2 batteries, safety even tesla use 2 the 12v and HV - replace the 12v Battery or put a Battery maintainer on it 2019 to 22 cars had lots of Battery issues due to car sitting especially when new and coming into the country,
The battery is an AGM type* and needs to be charged low and slow the DC to DC inventor is intelligent and doesn't charge all the time, it can take up 200 miles to get a full charge or 48 hours on a charger off the car - *some new cars use a lead acid
The battery is only covered for a year a dealer with fast charge a battery then test it, it then tests good do this a few times, and it spanks the battery
TLDR: suck it up and buy a new battery - oem is Yuasa or ask if they will do it as goodwill
1 hour ago, QldStew said:
I am having the same problem, and simply fail to understand the complexity! Why two batteries with no ability for each to back up the other? Why is the control system (which seems to be what goes flat) not on THE most reliable battery?
Toyota- lift your game! I have owned my Yaris Cross Hybrid for about a year, and this issue has caused me to call roadside assist now 4 times! they mean well, but each come up with different solutions! The local dealer is hopeless "not our problem"
The problem is, all the computers run on 12v, as do the door locks, lights etc.
The Nissan Leaf for example, will start charging the 12v Battery from the bigger Battery. But, there's one big difference.
The big Battery in a Leaf is a minimum of 24kWh. The 12v battery in a Yaris is 0.4kWh, the big battery is 0.7-0.8kWh.
You simply don't have enough in the big battery to keep topping up the smaller one, and a discharged HV battery can be a nightmare.
The HV is protected you need the 12v Battery to engage the contactors
don't mix up BEV and Hybrid as they are vastly different
What's different in this case though? Both rely on 12v contactors to engage the Battery, both charge the 12v Battery through a DC-DC converter. The difference is that some EVs will engage the contactors to charge the 12v Battery when the vehicle appears 'off' and whilst it isn't plugged in.
The problem for the Hybrids is that the 12v battery isn't that much smaller than the HV one, so charging it would require a not inconsequential amount of power from it. You'd not get many chances before flattening your HV battery.
Hyundai in their some of their HEVs and PHEVs use a Lithium 12v battery with a generous low voltage cut out. There's a button in the cabin to override that cut-out and still start the car.
  • Like 3
Today I tilted the solar panel to a slope of about 35st
According to measurements, the solar panel works fine and gives 0.8V more than when it is laid
Outdoor temperature at night -5C to -7C
Without recharging by the solar panel, the car Battery has 12.2V - 12.3V in the morning
10:00 - 12,5V
11:00 - 12,9V
11:15  - 13,2V
11:45 - 13,5V
12:15 - 13,7V
13:30 - 13,5V
14:00 - 12,9V
14:30 - 12,7V
16:00 - 12,6V
On 3/14/2022 at 11:20 AM, flash22 said:
The HV is protected you need the 12v battery to engage the contactors
It says hybrid on the Badge, manual, and key. What is BEV?
It's an abbreviation of  Battery Electric Vehicle (i.e what most people call an EV nowadays).
(As opposed to:
HEV - Hybrid Electric Vehicle - e.g. Prius, Corolla
PHEV - Plugin Hybrid Electric Vehicle - e.g. RAV4 Prime, Outlander
FCEV - Fuel Cell Electric Vehicle - e.g. Mirai)
Which app are using to monitor Battery voltage ?
I have a Toyota Yaris Hybrid 1497 Hybrid  from model year 2013.
I need to replace the 12V Battery because it has gone flat.
Nobody will do this for me and nobody can explain why or direct me to a service which can.
I cannot take the car to a dealer without paying for a flatbed truck, which seems excessive for a simple Battery change.
Toyota dealer doesn't want to advise as usual - they're only interested in selling new cars.
I have this issue on an older Yaris Hybrid.
It is absolutely infuriating.  It makes the car completely unreliable as you never know whether it will start after not being used for a couple of days.
Toyota dealers don't want to know.
Are you not a member of a breakdown service (eg. the AA or similar)??
I need to replace the 12V battery because it has gone flat.
I cannot take the car to a dealer without paying for a flatbed truck, which seems excessive for a simple battery change.
Sorry to hear you have a bad experience with typically a reliable car. 12v Battery in Toyota hybrids and most other cars from post 2010 my can go flat in the car has not been used regularly. Been a hybrid the car has a small 12v Battery that requires a regular drive for over 20-30 min each time or regular maintenance with external charger, your local dealer should have explained all that. Since the car has a completely dead Battery best practice is to buy a new exact type replacement battery, fit and measure if the inverter charges the battery correctly when the car is in ready mode (ignition ON and ready to drive). After that it is a good idea to buy a smart charger like ctek 5 or similar and once a month to connect and recharge your new battery to prolong its life. If you use the car often you don’t need to worry about it. You can search in Google for local mobile mechanic and book an appointment for battery replacement at your address. Batteries are available online or from Toyota dealers. Suggestion to keep the car in ready mode as long as you can when in use also helps to keep your battery in healthy condition.
Regards
AA, RAC and Halfords and all similar services claim to be out of stock on batteries for Toyota Yaris Hybrid.  There is clearly an issue here and they don't want to touch it.
It is a straight forward job to change batterie, Adam. Try You Tube for a video  "12v Battery replacement Toyota Yaris hybrid."
Wear a pair of gloves and eye shield for safety.
Disconnect the negative connection first, that is the black connection. Put it somewhere away from the red cable/terminal.
Disconnect the positive terminal, the red terminal. Put that away from the black cable/terminal.
The new Battery should be the same as the one removed, make sure the connectors are the right ones and positive connection is the same position as the old one. If the old Battery as a tube venting maybe through the floor then the new one must have Omit that if your battery is under the bonnet). Like for Like.
Putting the new battery in is reverse of the above ie red connection first, then black connection.
You can put some silicone grease, or better still dielectric silicone grease, on the 2 battery terminals.
Make sure the terminals are fastened up well.
The new battery may or may not be well charge, so do as Tony said above....... either take it for a good run at least 40 minutes OR in a safe place switch the car on so READY shows on the dash (tis is the position just before you put in D or R and drive off. Do this for 40 minutes.
Do the above charging regularly, once or twice a week in winter, probably only once in summer IF you do not use the car regularly or for only short runs.
  • Like 3
Cat, is it not the case that he can't source a Battery
The Battery is under the back seat, the Battery is made by Yuasa no where keeps them on the shelf apart from the dealer and a few sellers
S34B20R - 28800-21181 (right hand Negative)
price wise £130 to 160 delivered
random vid off youtube - ALWAYS disconnect the NEGATIVE first !!!!!!!
25 minutes ago, Roy124 said:
Cat, is it not the case that he can't source a battery?
No, he says he needs to replace it, it’s gone flat,  he says he cannot get anyone to do it, I know of places won’t touch a hybrid, no matter what needs doing*.  And he says Toyota dealer will charge him flat truck prices, which he says is excessive for a Battery change.
* back in 2018 I went to TAYNA batteries, Abergele, bought an AGM Battery for a Auris hybrid, I knew TAYNA didn’t do fitting but they sent me across the road to a garage. As soon as he knew it was Hybrid it was a no can do. When I got home I did it myself. Just didn’t have tools with me when I went for it, driving home with a new Battery would have been good.
But, with a booster or with cables and another car he should be able to switch the Yaris to READY mode and drive it till the dealer.
IF they have a Battery in stock AND they are willing to fit it, a bit of a not starter
IMHO the op should be able to find someone in their neighbourhood that can help them out, it's not rocket surgery
Toyota do a replacement 12v Battery under fixed price servicing for 105 quid. I couldn't buy the Battery on it's own anywhere for less than that.
That's fitted with a wash and vacuum to boot. You can book it online or through their app.
35 minutes ago, preperationlaunch said:
Toyota do a replacement 12v battery under fixed price servicing for 105 quid. I couldn't buy the battery on it's own anywhere for less than that.
It depends on the dealer as they are franchised dealers in the South like to screw every penny out of you, there are still supply issues
the Hybrid uses an AGM Battery, so more than likely not covered under that deal
