4 hours ago, Roy124 said:
It will be an accurate source, the limitation is with the display system specification and its circuitry.
I disagree in this case when the display is simply that. A display that just shows the reading that it's given. No translation or calculation involved.
CPN, we must agree to disagree.
OK. I'll agree that you're wrong in this case. 😉😁
  • Haha 1
There are two variants for the Toyota hybrid:
1/ fully charged car Battery has 12.2V
2/ charging voltage is normal 12.8V
In my opinion neither option is correct
there is a mistake somewhere
3 rides today
14.0-14.3V were only at the beginning of the drive for about 2 minutes and at the end when parking
1/ fully charged car battery has 12.2V
Totally agree with you. Nothing has changed in basic principles of wet-cell Battery technology since I did my C&G 1st Year back in the late 60's. An ordinary 12v car Battery with 6 cells fully charge should be 2.2v per cell and it should sit all day at 13.2v when new. Even dynamos in cars (as well as alternators later on) where commonly regulated to 14.4v while charging the Battery. So both of those Toyota figures are a bit weird.
I suspect they are applying the same charging principles that have been tested and recognised as good for longevity in the case of either Li-Ion or NiMh whereby the optimum range of SoC is between 40%-80% and never at a fully charged condition.
Trouble is, it doesn't work for wet cell batteries!!
It's probably just a case of a "sweet spot". CaCa batteries requiring over 16 volts means the car wouldnt charge it full anyways, but just cos it doesnt necessarily push it over 12,2v or 12,3v doesn't mean that Toyota thinks it's a full Battery. The hybrid efficiency is all about just that, efficiency. If the car was pointlessly charging the Battery all the time at +14v, it would hamper the EV driving.
So chances are Toyota have done a fair share of testing and decided that 12,3v is an acceptable charge (at some 60'ish% SoC) and they dont want to waste energy pushing it much above that. It doesn't hurt the Battery either, but yeah, it'll run dry and take damage easier that way.
It'd be almost certainly a simple software fix if they wanted to sacrifice some of the EV driving for higher charge rate on the 12v, but again, they probably found this to be the soft spot. I've seen enough flat batteries on non-smart ICEs over my years of driving to know that it's not a bulletproof solution either for people who dont drive much/drive short trips. It could be nice though if they allowed for some options, the car could even have a user setting for "battery reconditioning" or something where for a limited time it charges the battery at higher rate and notifies the user that EV driving % will be temporarily hampered by it or something. Would also be good for people who dont have a chance to use mains chargers. Also, for the love of God, let us monitor 12v voltage from infotainment lol
That said, I've noticed using my 12v socket voltage monitor on my (purely ICE) Aygo X and noticed it doesnt necessarily work much different to that graph. The alternator only kicks in when the voltage drops below 12,3v. And it does seem to have 2 different charge modes at least, one at/around 13v and one around 14v. Of course this voltage meter could be off somewhat, but its probably consistent with itself. It's a 65 Ah battery and the voltage meter usually shows 12,3-12,5v or then one of the charging voltages when driving.
As for the theoretical full charge voltage of a 12v battery, can't say I've ever seen that in real world scenarios and there's probably a reason why 12,7-12,8v is touted as a full charge. I suppose it's possible in practice as an open circuit voltage and in isolation, but likely not ever a reality when actually connected to a somewhat modern car with passive load on the battery
EDIT: Another ICE story. I had a Toyota Proace (dont do the same mistake as I did, it presents the worst of french engineering as a PSA car). It broke an alternator, but it behaved weirdly for a while (the alternator died gradually) so instead of suspecting the alternator, I bought a brand new battery for it. I didnt switch it until it left me on the road at which point I switched the battery on the fly. The brand new, full battery was within critical levels 30 minutes minutes of no help from the alternator. This is kinda interesting as it gives an idea of how small those batteries are if they arnt being charged. Or alternatively just how much electricity modern cars use. This also likely makes the idea of regular just-in-case charging of the battery with a main charger quite futile, as anything you probably gained might be wiped away after an hour of driving IF the smart charger decides to not step in before 12,3v. As such, it kinda also makes sense that in the search of optimal efficiency, the battery is charged just enough and not a bit more (unless you drive less than the magic limit and end up with a dead battery 😄 )
  • Like 3
I feel a tad disappointed with the 12v Battery issue with my toyota yaris.
Do members think an upgrade or modification might come from Toyota.
TIA
Maybe for a future model, but not retrospectively for existing.
Toyota has changed some problematic 12v batteries under warranty, but that will really help if the Battery is defective or just gone bad from too many times running dry, but the cause of the problems is still probably elsewhere
8 hours ago, Charliewatch said:
I feel a tad disappointed with the 12v battery issue with my toyota yaris.
TIA
The fixes are basically to use the car more, fit a higher-capacity Battery or use a trickle-charger.
I haven't had any problem with the 12v in mine in nearly 2 years of ownership, but I use it every day for work; I even accidentally left the lights on all day once, but it fired up first time in the evening so I didn't get stranded at site.
From what I've gleaned, you're only likely to have 12v problems if you hardly use the car, or if you had a duff Battery from the start (I suspect a lot of the earlier ones were left sat for a long time unattended during the pandemic times, and subsequent transport issues caused by new customs red tape following Brexit, and the batteries were allowed to discharge, which does a lot of damage to lead-acid batteries. Newer ones shouldn't have this problem tho'.)
  • Like 3
I bought a cigarette lighter monitor (despite my doubts about their accuracy) and the results are interesting. On starting Ready mode, the device momentarily indicates 11.9 volts and then immediately goes to 14.0 volts, without the ICE starting. When the ICE does start or when driving, the voltage remains with the range of 14.0 - 14.2. This presumably reflects the regulated charging voltage. When stationary, if I switch off and immediately go into ACC mode the voltage goes down progressively from 14.0 to 12.0 but I've not dared to let it go further down due to my previous experience in ACC mode.
Indeed, it seems to me that the current drain in ACC mode is likely to flatten the 12v Battery rapidly. It's probably safer to use Ready mode if you have to sit stationary in the car while, for example, waiting for your passenger to arrive.
  • Like 3
Your 11.9 volts reading is the equivalent of a 12.2 volt reading before you opend the doors to the car and moved key to acc mode if you weighted for a couple of seconds this display will soon drop even more say a extra 0.1 or .2 volts SO your 12.2 may be 12.4 volts before you opend the door.
Charging can be 14.0 volts or above.
  • Like 3
It has been said many times in the thread if you don't drive much leave it in ready mode when parked (supermarket etc) and this will keep the 12v Battery charged.
  • Like 4
@Charliewatch One of my questions was about the charging issue for the new 2024 yaris, but they would not comment, one thing for sure is they know about the issue so I would like to think that they have improved the issue some how, even with just a more powerful larger capacity Battery would help.
3 hours ago, Max_Headroom said:
It has been said many times in the thread if you don't drive much leave it in ready mode when parked (supermarket etc while your other half goes shopping) and this will keep the 12v battery charged.
Fixed it for you.  Your can't leave in Ready mode and lock it.
Of course they know about any issues these cars has. They have employees that only stay on the computer all day and read every single complain, post, or anything here and in any other media available to the public.
However Toyota will not come and say: “ hey guys sorry but your cars has faults in the 12v system or some production cars has faulty batteries installed or our dealers seems not following exact procedure for transportation and storage of our cars or they doesn’t do proper PD inspections etc” . No, but if you have any issues after new car purchase they will take care of. They will also look into it and improve with the time. They can’t improve owners uses, maintenance habits or drivers styles., or perhaps anything that doesn’t need actually being improved. 👍
I think he meant with the driver inside the car waiting. You can lock in ready mode with the key but it will be against the law.
  • Like 3
I thought it protested should you try and not lock it.  Agree your later point.
Not exactly correct.  You can lock it using mechanical key.
Edit.  I didn't see TonyHSD answer 😞
I did mean with the driver waiting in the car. It would be against the law to exit the car with the engine running on the public highway but probably not on private property, such as a supermarket car park. If you really need to, you can leave the car in Ready mode and lock the doors manually but not with the electronic key.
I have seen another make of hybrid sitting unattended in a car park with the ICE engine starting, presumably because they have left the car in READY mode, so there are some people who do this. It's probably safe, up to a point, but I wonder what the insurer would say if they knew!
RTA 1988, the highway code rules also apply to private property access to the public ie a supermarket car park.
Can someone confirm/deny whether the remote control AC function will start ICE if necessary or will it only use the traction Battery to the extent it can?
Cos if that function will star the ICE if Battery level needs it, then it was probably that.
Where did i say lock the car and leave it?
Fixed it for you - The relevant part is in bold below leaving in READY mode while waiting for the other half to do the shop has been discussed several times in the thread.
Quote
It has been said many times in the thread if you don't drive much leave it in ready mode when parked (supermarket etc) and this will keep the 12v battery charged.
Interesting. A few years ago, a woman damaged my car in a UK  supermarket car park and neither the police nor my insurance company were interested on the grounds that it was on private property.
