Can someone explain how to use ready mode..?, do I ,leave it in ready mode overnight?, or is it just for a set amount of time?, and does the hybrid Battery have to be full/nearly full..?
Hello , some advice please I own a 21 reg Yaris and like a number of new owners have suffered the inconvenience of the aux Battery failing. The AA guy attended recently and used a jump start kit to get me going. I have since purchased a yaber jump starter from Amazon, but have thankfully as yet not have to use it. In principle it appears straightforward to connect up and use.
I am considering purchasing a trickle charger to connect to the car when in my garage. However I have read reports that I would need to disconnect the aux Battery terminals before connecting up the trickle charger. As the said Battery is under the back seat, this may prove an inconvenience. Any suggestions would be useful. thank you.
Trickle charge from engine bay as in diagram posted further up.
Thanks, so no need to disconnect the terminals
5 hours ago, Primus1 said:
Can someone explain how to use ready mode..?, do I ,leave it in ready mode overnight?, or is it just for a set amount of time?, and does the hybrid battery have to be full/nearly full..?
Ready mode is just another way of saying the car's Started and Ready to drive.
Basically just start the car and leave it on for half an hour. Or go on a random drive :naughty:
e.g. A few people here wait in the car while their SO is shopping, but instead of turning the car off like you normally would, just leave it on the whole time.
But don't leave the car unattended as the engine may start during the 30/60 minutes in Ready Mode.
As others have already said, at least an hour in "Ready" mode should suffice and no, you don't need to leave it like that "overnight".
In relation to "does the hybrid Battery have to be full/nearly full", the system will always try to keep the hybrid main Battery (HV) between its "sweet spots" of ~40%<>~80% charge for Battery longevity and no, it doesn't need to be "full/nearly full". When you see the "compartments" in the visual display icons and they are showing all "full", that just means that the system has got it up to the ~80% mark and not, as you may think, ~100% SoC (system overall charge)
My car has often been parked up for a number of days showing only a couple of compartments full (~45%) with no detrimental affect whatsoever. It quickly recovers once you start driving about...
Thanks guys…
One of the useful things about having a built-on garage at the side of the house is that anytime I am in the kitchen making a cup of tea or coffee, I can use Hybrid Assistant on my phone to connect to the car's bluetooth and my OBDII adaptor (yes, it does work from the car through a brick wall!) to do a quick check of how the Battery is today...
(that's been standing since Christmas Eve and is the original 3+ year old Mutlu Battery...)
Alan asked a blindingly simple question.  "What is Ready Mode?"
I only discovered Ready Mode,  or rather had it pointed out by the AA man after recovering my car after the first lock down.
He told me to check it was in Ready mode.  I had no idea what he was talking about.
In 'old fashioned cars' you turned the ignition key and started the starter motor which fired up the engine.  When the ignition light and oil pressure light went out you were go to go ie in Ready Mode
Like CPN, I had 12.4 declining to 12.35v
0.05V drop in 6 days?  😮 I am quietly envious  😭
  • Haha 1
I may be completely wrong but I have religiously got into the habit of putting both key fobs to sleep (double click on "unlock" on the key fob whilst holding down the "lock" button) after the car is parked up and won't be used for a while and I believe that then, the car goes into a sort of "sleep" mode once it realises that it can't "see" the key fobs. This will only be on a Yaris with the full smart entry/exit system I guess...
Perhaps this helps to keep the current consumption down?...
  • Like 3
Hi been to dealers today for 1st service and got them to fit the leads to the Battery under rear seat so I can use my charger or solar panel without popping the bonnet
Nice neat job by the dealer at no cost to me
Another problem I had was connecting android auto to use my phone for navigation through the usb port
Apparently  the usb leads from your phone to the car  need to be data transfering  not a charging lead ,so a year on still learning about the Yaris
Due to get a Yaris cross in March 2024 for my wife so should have some fun again
  • Like 3
I thought the keyfob went into sleep mode after not sensing movement after 30secs or so..?
Not to the same extent as far as I know... e.g. if you walk up to the car with a keyfob set in this way, the car will not even see it and you won't be able to unlock the door by grabbing the door handle unless you actually push the unlock button on the keyfob (which also wakes the fob up).
In other words, just moving the fob has no effect on it.
Battery-saving function :
The battery-saving function will be activated in order to prevent the electronic key Battery and the 12-volt Battery from being discharged while the vehicle is not in operation for a long time.
In the following situations, the smart key system may take some time to unlock the doors.
The electronic key has been left in an area of approximately 6 ft. (2 m) of the outside of the vehicle for 10 minutes or longer.
The smart key system has not been used for 5 days or longer.
If the smart key system has not been used for 14 days or longer, the doors cannot be unlocked at any doors except the driver’s door. In this case, take hold of the driver’s door handle, or use the wireless remote control or the mechanical key, to unlock the doors.
Does the data cable also charge the phone?
Mine does 😊
I went for an Anker cable after reading recommendations..
8 minutes ago, Jasper. said:
Mine does 😊
Thanks, can you give us a link.
AFAIK a cables charge, only some carry data too.
3 hours ago, Roy124 said:
AFAIK all cables charge, only some carry data too.
Yes mine does ,I use the lead that came with my phone moto G 22 after trying various other leads without success
