I  just happen one larger ilet in my mix of various ilets & a crimpimg tool in my tool kit.
M8 or M10 electrical eylets they as cheep as chips on eBay but I would reccoment a crimping tool.
I have known people just bash them with a hammer after inserting the insulation from wire and sliding the eyelet on.
Sorry that shoud be stripping insulation
9 hours ago, Derek.w said:
M8 or M10 electrical eylets they as cheep as chips on ebay but I would reccoment a crimping tool.
I have known people just bash them with a hammer after stripping insulation from wire and sliding the eyelet on.
Thanks but if the CTEK adaptor is only up to M6 or M8 how do you attach a M10 to it? Sorry if its obvious!
Just posted pictures of crimping pliers and some fittingsIMG_0317.thumb.JPEG.dab823721e1a118ebac7d7af74b5e0f3.JPEG
You have to cut old connector off bear back wires push wire into hole on new terminal and crimp it ie squash fitting to close it up around wire.
PS if wire looks very loose in the fitting hole then remove wire end bend it back on itself reinset and crimp if it has a plastic sleeve crimp this also both operations can be acieved in one go with a ratchet type of crimping tool.
I've had a 2021 Yaris Dynamic Hybrid for one year now and have had to jump start it 4 times now after being in the garage and not used for 3 to 4 days - not good. Before the Yaris I had a 2008 non-hybrid Auris and used to park it at Gatwick airport for two weeks and it used to start fine on my return. My only option was to purchase a semi-professional power pack/jump starter and keep it in the boot (a life-saver). This Battery low state is not what you would expect from a brand new Toyota. Plus I know when it will not start as the brake pedal pulsates - this is 'Hybrid Happiness'.
On 7/20/2022 at 7:43 PM, TruBlu said:
I've had a 2021 Yaris Dynamic Hybrid for one year now and have had to jump start it 4 times now after being in the garage and not used for 3 to 4 days - not good. Before the Yaris I had a 2008 non-hybrid Auris and used to park it at Gatwick airport for two weeks and it used to start fine on my return. My only option was to purchase a semi-professional power pack/jump starter and keep it in the boot (a life-saver). This battery low state is not what you would expect from a brand new Toyota. Plus I know when it will not start as the brake pedal pulsates - this is 'Hybrid Happiness'.
Unplug the D/C CUT on the fuse box inside the engine bay.  With that, you do not have to worry about wiggling around and reconnecting the wire.  It  should be enough for about 1 month.  Otherwise, buy a Battery pack from Lidl/Aldi for jump start.  you do not need expensive big jumper.  It only needs 60Amps to start and £15 Li Jumper is good enough.  It disable all the body controller unit and reduce the Battery drain significantly.  I have Auris 2016 and I never have issue with the batttery but all the lights will be off after 15 minutes even if I forgot to close the door.  Not sure about Yaris if it has Deep Sleep mode.
TruBlu says he has a jumper pack, this is a good investment as there can be other occasions where you flatten the Battery such as side lights or flashers left on.
However 4 flats after 3-4 days is definitely not normal. After 3 flats over the first year my garage changed the Battery for a larger capacity.  After a 2 week valet park the car was returned and no comment made.  Later, after a period of Covid isolation it still flattened over 8 days. I had a charger but chose to see what happened.
Anyway, before the garage changed the Battery I monitored the battery voltage drop day by day while the car was unused.  I was able to show the garage and presumably their checks showed defective cells.
If you can, do the same and discuss it with your garage.
I have a 2021 Yaris hybrid and it also has a recurring flat 12v Battery problem which has meant the car wouldn't start on 4 separate occasions. The AA/Toyota Rescue man said it was common call-out for him. The local main dealership seemed aware of the issue, which is common to the CH-R too, but not the new Corolla which has a bigger, better Battery, I was told. My Yaris needs to be driven for 30mins at 60mph once a week or left with the engine running for an hour. A better Battery is not currently available for it.
This is my first Toyota and it's most unreliable car I have had.
Jr, can you tell us a little more about the flats?
How long between your last drive and the flat?  What driving had you done before you had a flat Battery
How long was it between you experiencing a flat Battery
In hybrids 12v batteries need much more attention than in ICE and certainly appear to be a weak link not just in Toyotas I believe.
I can't comment on higher capacity replacements for Yaris but my Corolla was refitted with one 20% greater capacity; it still went flat after 8 days.
Consider buying a low cost booster Battery, about £30, which can get you going faster than the AA man getting to you.
If you can, measure the battery voltage each day you are not using the car. You can then badger your garage to do something if the voltage drops off over just a few days.
The Battery needs replacing, due to lockdown and many cars just sitting batteries fail if kept at a low state of charge it will lose its capacity over a short period
looking up the Battery in the EPC shows it to be 28800-K0020, LN0 type - next size up is a LN1 what's 30 mm wider
Hello all, Toyota agreed to replace the 12v Battery on my 2020 hybrid in May. Since then I’ve not had any problems (fingers crossed) although it’s not Sat not being used for more than 5 days. I’m still concerned though about eg leaving it at the  airport for 1 week or more.
I looked into buying a car jump starter (generally seem to be circa £80-100, ones most recommended) as spoke with AA who’ve been out to me 3 times. I emailed my Toyota garage to check the particular one I was going to buy was ok for the car (and push start model) but I’ve had no reply, which is disappointing, as I also was saying thank you for replacing my Battery
Has anybody bought a car jump starter and used on hybrid yaris which you can recommend, please.
Also, Roy123 - I’d like to be able to check my voltage but I don’t know how to - can you advise me please
thank you
Yes, I have purchased following powerbank following a good online independent review I found, from following company:
https://www.mobilesolarchargers.co.uk/shop/details/overland-waterproof-car-jump-starter
I have had occasion only once to use on my 2020 Yaris Launch Edition after it failed to start during one of the lockdowns and it started up the car via the front jumpstart terminal no bother.
This is very similar to the one I got:
Nicoone Car Jump Starter,8000mAH 12V Portable Car Battery Booster Jump Starter with LCD Flashlight,Car Power Bank Charger for Automotive, Motorcycle, Tractor,(Below 2.0L) (Red) https://amzn.eu/d/7835GEq
Simply fasten to positive terminal and an earth.  That should be sufficient to energise the 12v system.  It holds the charge well, has a torch, can be charged using USB, and provide power for a mobile phone.
The check your Battery voltage simply attach a voltmeter instead. Something like this will do the job and can have lots of other uses too:
Digital Multimeter Car Battery Circuit Multi Tester Voltmeter Ammeter OHM AC/DC Voltage DC Current Continuity Resistance Diodes Transistor Electrical Test Meter with Test Leads Backlight LCD https://amzn.eu/d/6yRrcwO
I am very tempted by a bluetooth, 12v monitor like this:
Battery Monitor BM2 device for Cars & Campervans 12V Battery/leisure battery tester Compatible with Android iOS and Ipad with bluetooth 4.0 and above. https://amzn.eu/d/4uQfU5E
The advantage of buying through Amazon you have 30 days to return it if you decide its not for you.
thank you
Hello Roy124 and AlfK
Many thanks for sharing the links to the products. I’m going to purchase a jump start to keep in the car as back up and the volt metre as that will be good to use to check every so often.
I’ve had 3 petrol Toyotas and reliability has been a key feature of the cars - last one 130k+ and started first time after I’d been away for over a month.
It’s a shame the hybrid has this unreliability and Toyota don’t seem interested in providing a solution, other than a new Battery, which I was thankful to receive.
I had planned to get a dash camera fitted but as that works from the 12v I don’t want to risk adding anything other equipment which is going to draw on the Battery!
thanks again, for the advice/recommendations
Joby, my Battery pack has 4 led to indicate charge. Two are red and two blue.  All 4 indicate over 75% charge. 2 red, 1 blue over 50, 2 red over 25 %.
I have used it to charge a mobile and in April to start the car.  I charged the pack after that in April. I have just checked 3 months on and have 4 led.
That’s good to know Roy. I’ll order one of the Nicoone.
I would like to share my case. I just bought my 2016 Yaris in April this year from the dealer. I use it 2-3 short trips a week. It cannot start up itself last week, need a jump starter to start.
I sent it to Toyota service centre and they said the 12V Battery is dead due to my low usage. They need to replace the Battery with new one. Unfortunately it is not covered by the 1 year warranty. It cost my over £100.
The technician told me to drive the car approximately 10000mile/year to keep the 12V Battery in healthy status.
I think I will never drive to this mileage for my use. And going to buy a smart charger to charge the battery maybe once a week from home socket.
9 minutes ago, isnsiie said:
The technician told me to drive the car approximately 10000mile/year to keep the 12V battery in healthy status.
I'm sorry but that is just plain rubbish you have been told! We purchased our Mk4 in October 2020. In 22 months of short journey use, we still have only 3,984 miles on the odometer and it has never failed to start once. When I first connect my Hybrid Assistant (before I actually start the car) it has sometimes shown as low as 11.8V but the car still starts perfectly when asked...
Shows you the calibre of "technician" 😀
Maybe they finally find the way to kick me out of the official warranty.
I have no any hot wired equipment. So I am sure there is nothing drain the Battery.
I am going to hot wire my Dashcam and install a gps tracker, so I decided to charge the Battery with a smart charger by myself.
They probably just mean "You need to drive the car more" - I know in my job I've learned that if I try to explain something technical to a client in the plain 'truth', no matter how simple, they will just glaze over and not take any of it onboard, so I've learned to just make something up that they will understand and make them do the desired behaviour to stop them breaking the damned thing all the time :laugh:
6-10 years is about right for an AGM Battery, you don't know how long the car had been sat before you got it, lock down has killed a lot of batteries, the Dealer will just charge a Battery, and let the poor customer pick up the tab a few months down the line for a new one, at least they only billed you for the Battery at trade price not retail (£150) + £30-50 for fitting
Just replaced my friend's battery after 10 years (62 plate hybrid) that had been sat 3 months due to his wife having cancer
