Yaris T-Sport 1.5L Fuel Injector Alternative
- A - Go -
Hiya all, a quick question please!! What other model toyota or any other vehicle make fuel injector is a direct swap and same type please, basically alternative!
Cheers
J
All t-sports are Japanese built
if you are doing the injector, change the insulators as they will be hard as a rock, if you are chasing a misfire change the intake gasket too for something like a Victor Reinz 71-53089-00 (Toyota 17177-21020) as they go between cyl 3 and 4 - again, old crispy rubber
Injector - 23209-21020
Insulator - 23291-41010
Yaris and Yaris Verso 1.3 Japanese production with enginecode 2NZ-FE are the same.
iirc there the same as the prius, plenty of Chinese junk on the market at less than £15 an injector
Hi, thanks, regards to the chinese junk, what are those injectors like, anygood?
Cheers! J
Last time I bought injectors was for a custom install on my classic and even then the first set I bought would not fit, far too long. The replacements fitted but had a different flow rate so the ECU needed a different map, luckily the supplier had one and updated it FOC. The were about £350 a set for both the Bosch originals and the Weber Marelli Pico replacements.
Hate to think what some of the "foreign" stuff is like.
The Weber Marelli ones have been in for 19 years next March so happy with those.
