The darkness is calling...
Whilst I have read some of the hand book... between work and having a 9 month old its been hard to spend the time reading or in the car fiddling with some settings.
I wondered if anybody knew if the night mode/dark mode could be enabled at all times on the centre screen. I find the white background a bit too distracting (even in the day)
Many thanks!
jack,
This was posted on another forum regarding this issue, hopefully it will work on your model.
Look on the side of your dash below the steering wheel there is a row of button and a wheel to the far left. Turn the wheel out of the top position you will feel a click and it will now be in the position to go into night mode also you can vary the bright to dim settings to suit yourself.:smile:
3 hours ago, Bper said:
Jack,
Many thanks Bob, I will take a look at this tomorrow 🙂
