I notice in the fog last night that my RH headlight is pointing to the left, I have searched for Adjusment horizontal and there appears to be vertical adjustment only.
Is that just on dipped beam? If so I believe it's normal and hence the reason beam deflecters are used when driving on the right abroad.
You will soon know for sure Dan, as you will soon be tahing your car for its first NCT. In the meantime I wouldn't touch it.
It's on main beam
15 hours ago, Roker said:
It's on main beam
I don't like it, it leaves  blind spot. Can I assume everyone else has the same and there is no adjusment
Yes, everyone else with same spec Corolla will has the same headlights.
Only the excel trim levels in uk from 2019 to 2022 has much better projectors led headlights that are one of the best on the market together with some other top spec Toyota models. Icon, design and gr sport has reflector led headlights that aren’t as good as the projector ones found in excel.
