Engine Oil mixing (same brand)
Mo Ali
12 hours ago, Mo Ali said:
Handbook says use Toyota's 0W-20.
Any brand 0w20 will be fine for your car.
Mobile1 is usually the supplier for Toyota oem engine oil here in Europe.
Good quality brands you can use are Castrol, Shell, Total, Elf, Motul, Petronas, Millers.
Here a good place to buy oil from https://www.opieoils.co.uk . They sell on eBay too and with free delivery.
Here what I bought yesterday for myself https://www.ebay.co.uk/itm/323898248620?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=3hyRrutZQQ-&sssrc=4429486&ssuid=p34UK1z2T4m&var=&widget_ver=artemis&media=COPY
If you have half litre left over and buy these 4x1ltr pack you will be ok for another year and if your car does not consume oil and you don’t need to top up or store any oil around.
The spec is exact match for most Toyota hybrids 2010-2019.
Thank you Tony that is exactly what I had in mind to get 4litre ones.
Bit off topic, but to save me trying to desypher the technical specs,  can someone give me a good engine oil brand & grade for a 2013 Yaris Hybrid. Have asked Roundswell Toyota three times but they can't be ubikd to rely!
Edit. Oops - didnt see the previois post!!
Edited by TDG
Didn't see previous post!
Back in the day when I was directly involved in the operation of BIG ( 760mm bore x 2500mm stroke) marine diesel  engines it was the various grade of Mobil oil that stood out for performance and service.
you can use this website to locate engine oil. https://www.opieoils.co.uk/c-650-0w20-engine-oil.aspx
Any 0w20 Spec GF-5 or GF- 6, or A5, A6 will be suitable.
Those specked with C are specifically made to comply with modern emissions system in later cars like dpf, gpf, or similar. The oils are absolutely fine to use in your hybrid too but not necessary.
My personal choice for engine oil since 2016 is
Petronas syntium 7000 0w20. I usually buy from eBay
https://www.ebay.co.uk/itm/354160210983?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=qqtnj62vtai&sssrc=4429486&ssuid=p34UK1z2T4m&var=&widget_ver=artemis&media=COPY
If you are about to spend £60 or more for 5ltr engine oil perhaps just buy one from the dealer of is around these money. It will be mobile 1 in Toyota bottle. 👍
