So it has 2 reverse lights then ? If so, that's fairly simple
the last pic you posted are LED tail lights the white connector is for illuminated tail lights, your JDM car has the standard tail lights with no LEDs
Its 2 reverse lights, change the bulb on the driver's side to a red one (921 bulb IIRC) rewire and a run 1 wire
Bit confused how would I run a cable to a switch at front as reverse lights only come on with gearbox.
is it possible you to PM your number and we have a 5 min chat again I’m happy to pay for your time , please 🙏
Cut the wire, change the bulb to a red one, converting it in to a fog light
sadly, it's a bit of a trek for me to your location
Such a shame , again if you’ve got a spare 5 mins I think a quick chat would be better than messages as I get confused easily 🤦‍♂️
which wire are we talking about to cut ?
also would I still need the new stalk with combo front and rear fog lights as separate selections ?
If your saying pin 3 up front is energised with this and then sends power to pin 18 in rear passenger side on boot then it seems I would need to fit combo stalk and then wire a fog to the output of pin 18 is that correct ?
plus I’m not sure if it will pass IVA with 1 reverse light🤷‍♂️
So what I’m planning on doing is fitting the new stalk and seeing if I light comes on for rear fog then trying to find where on the wiring the rear fog lights are , any ideas is it the 3 pin connector or in bumper ?
Worst case as you said change bulb and wire a separate switch but i want to avoid running cables though car.
Apologies again but so you perhaps have a wiring diagram ?
Have a feel inside the tailgate for a large connector, the loom comes down inside the tailgate and joins in to the tailgate loom
IVA wise all it needs is 1 reverse light on the passenger side and 1 fog light on the drivers side
Check for the wiring at connector 3D
fit the stalk add the RR fog 7.5a fuse
i only have a few wiring diagrams for the JDM vitz
There is a large 3D connector in tail gate
are you talking about this ?
I will fit stalk and see if pin is energised where you said at glove box location.
do you know how the steering wheel cowling comes off ?
again I really do appreciate your time and patience with me
3D is behind the glove box
Progress located the 3D
so everything is now ready to test when the stalk arrives
I assume I would remove the connector and then turn on stalk to see if a connection goes there with car off or on ?IMG_8767.thumb.jpeg.efc7ee3cd8645357886c03b94dd340d3.jpeg
You just need to confirm the wire is there and the colour (should be green, but it is a JDM car) - add the stalk and the fuse
behind the glovebox, have a look at connector 3D - Pin 3 should be a green wire - 3rd pin up on the right as you look at it
Ok mate
both 3rd pin on right and 3 pin up from bottom are green see images IMG_8780.thumb.jpeg.af29ce8ae0318619cc83d8ae5bb49323.jpegIMG_8779.thumb.jpeg.a496b42394e463f575bfff76a2e240e6.jpeg
does this mean I can fit the new stalk and tap the fog light from one of the rear 3 green connectors ?
also when I remove airbag will the srs light be an issue ?
I will disconnect Battery of course , for now my plan is to just plug stalk in place without fitting and test to see if the symbol lights up.
I have now got a Uk tailgate unit with fog and reverse light in 1
however following the 3 green wires from the unpopulated connector block I can see they all go to powers , ie num plate light and such so all 3 go somewhere but there is a light green colour from the big connector that goes nowhere and shows up on 3D connector at front though it’s pin 6 not 3 so wondering if that’s the magic wire ?
again thank you , please let me know when I can buy you a beverage of your choice
3d is the top plug, The foglight wire I have arrowed for you
in the tailgate, the two connectors taped together are cable splices (wire joiners) The three dark greens are tail lights only
what colours do you have on the other part of the connector
IMG_8751.jpeg.a599b5fa78918e38791a03b4cb
Airbag, you do not need to touch it for testing, don't forget to add the fuse low profile Mini 7.5a
when you do want to swap the stalk - disconnect the Battery for 20 mins before touching the airbag
when you have the stalk you can go chasing wires, I will have to look up 3D pin 6 and what it does
1909302894_2560px-Electrical_fuses_blade_type.thumb.png.de97b1d8d3ff645cb2b608582b89de52.png
3D, pins 7 and 8 have to do with locking, unless it's some weird JDM thing
This is all the wires for the big connector
IMG_8750.thumb.jpeg.04038484ab7d4c07effa5d5ab3f4b6da.jpegIMG_8783.thumb.jpeg.f124893bcf0fae5abae40f6e3402fd7a.jpeg
so can I just unplug current stalk and then plug in new stalk (with power off)
then probe green wire in big connector ? (When I flick rear dogs on)
as I said the only green wire free is the very light green one in the rear connector
also do I put the fuse in the code box in engine bay ?
hopefully soon as stall is here I can do a rough test , if Iv got a long enough cable I could run one from 3rd pin at front to rear without switch to see if it’s running back
the 7.5a fuse goes in the fuse box under the glove box - if you see where 3D is, it's in the bottom of that unit, accessed from the footwell
the light green runs to the back of the car it then connects to the harness that joins the tailgate
So can I plug the stalk in without fuse just to see if dash light comes on mate ?
also what specific location in fuse box do I put the fuse ?
not sure on the exact placement of the fuse it will be marked on the lid
Toyota-Yaris-_-Vitz-XP140-2011-2018_in_f
Cheers mate found the fuse pin out I’ll just swap front for rear just to test as I couldn’t fine low profile ones
One last question I saw you did a cluster swap , how can I safely remove the needle to remove my speedo facia
is it just spin dials anti clockwise or prise up ? I’ll be sure to tape alignment
merry  Xmas and a happy new year btw
stupid stalk hasn’t showed up have messaged amayama to see what’s going on as I’m itching to get this working and tested
4 hours ago, flash22 said:
pop the needle off with 2 teaspoons, one either side and use them as levers or pull upwards - no fancy tools and I have done it this way for many years
A random vid off YouTube
https://www.youtube.com/watch?app=desktop&v=2vsZaryVhKo&ab_channel=Mark'sGarage
Thanks I have plastic pry tools
so more progress
I have located the fuse and indeed the rear fog does already have one (I’m praying this bodes well) but rather alarmingly there’s a 20A tail fuse missing - any ideas why or what it is for ?
I also have steering bottom cover off so soon as stalk arrives I can plug it loosely in and test
again mate I’m very thankful to you for your help and hope you have a nice festive period
the tail fuse is 10a and is correct, I think you may have flipped the diagram
looking at your photo
bottom row  right is fuse 1 - 13 on the left
1, 2, 3, 5, and 6 are not used
Tail fuse is fuse 39 Top row left corner 10a
https://fuse-box.info/toyota/toyota-yaris-vitz-xp140-2011-2018-fuses-and-relay
Ah ok
well stalk is in UK so hopefully I get it tommorow and can test , I’ll have to relook at pins but I’m told by auto Electrican that it should supply 12v when switched on
Well stalk arrived and fitted in place
tried chasing some cables but got scared when I connected to top pin 2 at big connector on boot and car gave me a warning on dash , a pin out would help for this connector if you have one please ?
got a auto Electrian coming as I don’t think it’s worth the risk me  blowing something up !
assume rear fog is meant to be orange ?
also how do I fit this new stalk ?
Seems a hassle to be honest wondering whether I’m better off with a simple switch but be happy to hear your thoughts 06183977-A783-41F2-917E-CA6654BB939E.thumb.jpeg.46804934f8ba3c66a7142ba0bad0d31d.jpegC21966FC-F304-48A9-A69B-06510D94EDBB.thumb.jpeg.226d6ed3e4fdc0f40141d038240e3556.jpegIMG_8829.thumb.jpeg.cfdfcc6cd5598b37463205b6788aee72.jpegIMG_8828.thumb.jpeg.078fb8220c890a13d5e713fae85e1b34.jpegIMG_8828.thumb.jpeg.078fb8220c890a13d5e713fae85e1b34.jpeg
