Hi, I had took out the am2 fuse and replaced it with new one but now for some reason the car doesn't start weird. The car is an urban cruiser diesel.  All power is fine tried to knock a little the started motor still no joy.
I can add a video of need let me know.
any help will be greatly appreciated.
What caused the AM2 fuse to blow ? Was it jump started backwards ? I would look to see what the AM2 fuse feeds
AM2 Feeds the IG2 relay, in turn it feeds the ignition switch in also feeds the BCM via AM2 No.2 7.5a*
* 08/2010 onwards only
Nothing tripped it I had swapped it for newer fuses.
Why change it ? It may just be a junk fuse from China replace it with a better quality one, as they say if it ain't broke, don't fix it
I even put the old one back still the same. Soit seems like some may have reset somewhere?
The fuses I replaced were from Halfords.
I agree Chinese products may not be good hence why I got them from Halfords.
did you get the correct type of fuses
Halfords - the "low-profile mini" fuse is sometimes incorrectly called "Micro" - Micro fuses will fit but will not make a decent connection in a low profile mini fuse box
1909302894_2560px-Electrical_fuses_blade_type.thumb.png.de97b1d8d3ff645cb2b608582b89de52.png
If in doubt, disconnect the Battery for 20 minutes and let every thing reset
If in doubt, disconnect the battery for 20 minutes and let every thing reset
I will disconnect the Battery thanks in the meantime here is the video
Thank you for your help, turns out that the Starter motor had gone.
