Replacement bumper
Joan Crawford
Hi all,
Someone has crashed into my Yaris and damaged the rear bumper. My Yaris is a 2013 trend VVT-I 1.33 litre white car. I think the engine is a 1NRFE engine based on the engine size and when it was manufactured (sometimes put as NSP130). I have been able to find a bumper which looks exactly like mine including the sensors but says its for the same car but the 1 litre version - 1KRFE or KSP130. Are the cars the same size? Will the bumper still fit even though it is for a 1.3 litre engine car and not the 1 litre engine car as specified?
Any help will be great thank you.
engines have nothing to do with the body as long as the bumper is the same year 2011 - 2014 mk3 yaris,
2014-2018 is the first facelift (different bumper and rear lights)
2018-2020 is the second facelift (different bumper, tailgate and rear lights)
I suggest you check the brackets on the corners as these tend to crack/snap also check the tabs on the bumper its self as these are made of cheese
Are you sure? I've seen other pre-facelift models as mine that have a black lower section to the back bumper that mine doesn't have.
Yes I'm sure, lower spec models don't always have the extra trims the upper models do
