Posted (edited)
I have a fairly old Corolla  (1998, 1.3 HB) with I am pretty glad too own and drive in. 😊
But my abs failed and I can’t find the problem.
There is power to the main fuse (50amp)
But there is no power in the connector at the abs module/pump.
Does anyone have wire diagram otherwise know where too look for this problem.
If I short cut the relays I can hear them working.
Perhaps there is a wire diagram for the abs I can see so I can start to measure where the problem with the power starts.
Hope my English makes sense because I’m from Denmark, and can’t find any danish’s forums like this here.
Thanks in advance 🙏🏼
Edited by Molledk
I had missed some information
Hello Jacob - welcome to Toyota Owners Club.
Topic moved to the Corolla forum.
Below are the circuit diagrams for a 2004 corolla which might give some idea of how  yours is wired ;  assuming Toyota did not make that many changes to the ABS between 1998 and 2004 ?
Thanks, i will try it out 🙏🏼
