Auris e180 service indicator
solero
Is the spanner service indicator. Purely mileage based or also time based?
Eg would the mileage countdown deceesse with time even when stationary for long periods (12 month vountdown)?
  • 4 weeks later...
I think it is only Km base.  If you have pre-2014 November made 1.8 hybrid Auris, don't overdue oil change. The engine will consume a lot of oil and at the end cause more troubles and more oil per year.  Change the oil maximum 5-8k miles interval, 6-8 months instead of 1 year.  If you have post 2014 November made engine, it has revised piston rings and pistons  and has less likely consume engine oil even with 1 year interval.
