Back seat belt chimes I won’t off
Michael j M
My back passenger seat belt chimes goes off even when plugged in ,I want to disable all the chime noises what can I do from uk avensis
Hi Michael, Previous posts have said this can only be done with Toyota techstream, others have said to plug the rear seat belt in but yours keeps going off regardless, Hopefully another member may have come up with a better method but you can try this which was recommended by a another post. Hope this helps:smile:
Hey guys,
I resolved your problem by resolving mine.
At the end of the buckle you have the black switch from where the cable goes under the seat. Unplug the cable and you won't have either chime or warning light on the dash.
But guys, always wear the seat belt!!!!
