Beep sound from car while driving
Dimitar Genchev
Hey All,
would anyone be able to help me figure out why my car makes this beeping noise as I have no idea. I have a Toyota Yaris VVT-I EXCEL M-DRIVE S hybrid car and while driving it, it occasionally makes this beep noise. It sounds once and can happen once between minutes or hours of driving. No warning lights get illuminated on the dash board. You can hear the beep sound in the  video from the below link, it happens right at the end of the video (last few seconds).
https://veed.io/view/76927b22-7c37-4a44-b77d-dda61e164ede
Turn off the lane departure (long press on button on steering wheel) to see if that fixes the mystery beep.  Mine beeps sometimes when you go over a repair/joint in the road thinking I'm wandering across a lane.  Annoying.  Like the lane centering going crazy at junctions with lots of white lines/hashing - it will suddenly try and steer right all on its own. I try and remember to turn it off at the start of each journey.
It automatically restarts every time the car is restarted, and you will have to use the cancel button on the steering wheel each time you want to turn it off. It’s a safety related thing.
Either that or you have a road runner in the boot...
Alex
  • Haha 3
Mine does that if the boot is not closed properly or one of your doors is not closed
Are you sure is not the cold temperature warning or Ice road warning as this time of the year it started beeping for me also.
Another idea if you have tire pressure monitor would be to check the tire pressure for all the tires as the pressure sensors inside the rim could detect a tire is low due to cold temperature and that would beep also
Hope this helps 🙂
