Oil change on a 2.0D4D Toyota Avensis 2014
2009joe
hello there toyota world how are you guys doing happy Christmas hope you had a good one. quich question when changing my car engine oil is ok to run through liquids molly engine flush first to clean up the engine or is that a bad idea just change it with genuine toyota oil will be ok
this stuff
https://www.liqui-moly.com/en/gb/pro-line-engine-flush-p000065.html#2427
this stuff
Happy Christmas Joe.
I don't see the need for engine flushes.  The main purpose of them is to remove sludge deposits from the engine.  Changing the engine oil often will avoid the build up of sludge in the first place.
Probably no harm in doing it if you want though.  Although there will be a slight risk if you have any damaged oil seals that are being kept sealed with sludge, they could start leaking.
Hi its good to do flash only if you start it from early it means 50k mills do it and put a new oil and filter after that every 30k or so and the all system stay like new, if you do it after 10 years of never done it before or, after zero maintanance then there will be trables so dond.
It depend also in the condition of your car.
I for example did it after 50k km ones, change oil every 5000km with an oil pump, oil filter every 4 changes of oil use 0w20 winter of 5w30 in summer, the car runs like new !
Enjoy.
Enjoy.
thanks so much well i bought the car with 38k on it and now 3 or 4 years now i have about 60k on it now do u think its ok in these toyota 2.0 engines with dpf to do the engine flush will it wreck anything do you think
I i was you i would put a flash can before oil+filter change, and put new 0w20 fresh oil with a new filter and if you change oil every year, i would keep on doing flash every 2 years.
This flash take all the dirt moister and so... out of the system/going back to the original point from the day it went out from the factory.
Keep the system clean and anjoy your car.
I never heard of this flash can thing do you have it on and could. You send me a link to the one I should get to put on the car plus where dose it connect up to on the car .thanks for your help
I once made a (previously quiet) high-mileage petrol engine really tappety by using engine flush, and have never used it since. As long as the oil has been changed at the correct intervals in the past there should be no need.
