Can't change kmh to mpg
MaxM
Hi
Does any one know how to change this kmh gauge to mpg?
As you can see everything else is in mpg.
2 hours ago, MaxM said:
Hi
I'm fairly sure that that is exactly as it is supposed to be. It's showing you your remaining range in miles, and you current speed in both MPH and km/h as it should.
Go to settings menu (cogwheel symbol) - scroll down to "Settings" (not "Vehicle Settings") - long press "OK" button on the left of the steering wheel - scroll to "Units" - press "OK" - select the required units. Three different options available:
km(km/L)
km(L/100km)
miles(MPG)
Hope this helps.
You're supposed to be looking at the big MPH display in the middle and not the tiny auxiliary kph display on the side :laugh:
At least in the UK you can do metric and imperial, which is great fo when you drive in Europe. In my French version I can only do metric which is fine except when I drive it in the UK. Toyota clearly have double standards.
