check hybrid system
olugbenga
My Toyota Prius  car stopped working with error check hybrid system. it was diagnosed with below error
Diagnostic Codes
RAC DIAGNOSTIC SYSTEM
System Type: ELECTRO DRIVE
DTC: P0A94,DC/DC converter performance
System Type: BRAKES
Name: ANTILOCK BRAKING SYSTEM/VEHICLE STABILITY CONTROL/TRACTION CONTROL -
ABS/VSC/TRC
DTC: C1259,EV Control System Regenerative Malfunction
DTC: C1310,HV system
Pls i need a garage in either Sunderland, Washington or Newcastle that can fix the problem for me.
You need a Toyota dealer for this fault. I would not recommend going to other garages.
Sunderland Toyota is: Toyota Wearside, Newcastle Road. Tel: 0191 357 6565.
Toyota can do a full hybrid check on your car. If you have your car serviced by Toyota a hybrid check is included.
Hope you get. It sorted.
  • 3 months later...
Hi. Any updates here? I have the same issues since yesterday.
