Rear right headlight connector diagram
TOMEH
Hello,
Could someone help me to find out the correct colour of the connector my brother tried to see why there was water in the trunk. While he is taking out the lights he broke the right one connector cable. I just want to know which cable is which (like the colour and the pin place)
7 minutes ago, TOMEH said:
Hello,
Car:
Toyota  AurisTR  2009
here the connector after I connected again 🤦‍♂️
Green - tail lights
Pin 4 - red - reverse
Pin 3 - sky blue - rear fog
Pin 5 White/black - ground
Pin 7 - Blue - Stop
Are you in the UK ? Does the VIN start with 1SB
you have some wires in the wrong places
Pin 3 - Sky blue - rear fog
Pin 4 - Red - reverse
Pin 5 - White/black - ground
Pin6 - Green - tail lights
Pin 7 - Blue - Stop
The VIN number starts with SB1 and I am in the uk
Edit: Also I have 6 wires:(
Pin 7 - Blue - Stop
The VIN number starts with SB1 and I am in the uk I have 6 wires
The wires are wrong because I tried to put it back together 🤦‍♂️
20240103_132738.thumb.jpg.a0f4453525a7c76f7a58cbdb9dfbab98.jpgScreenshot_20240103_132706_Gallery.thumb.jpg.fd7c5f3ef194e6f3477b83d935f806d4.jpg
🤷‍♂️  i think there might be a problem with the connector
Does anyone know how much would cost to repair this?
They are an IDC connector, you place the wires and push the lid down to connect the wires
90980-12517
I will double-check the pinouts
Pin 1- Sky blue - rear fog ?
Pin 3 - Sky blue/flag  -
Pin 7 - Blue -
90980-12517
Pin 4 - Red - reverse * no need for it if the lights doesn't have reverse
Pin 7 - Blue -
Thank you, I took it to garage and  they welded it the lights  because we couldn't find a connector
Also I was today years old to knew there it only needs 5 but had 6 because they could change the fog light to reverse if need in another country 😁
