1998 regius hiace
arabpj
hello,after some years of trying to figure my troublesome idling. it seems to be prado running gear and 1 kz diesel.I drove short distance using only handbrake. engine ok. As soon as i applied footbrake engine increased from normal idle speed ran rough and like a hunting motion.play with throttle and wait for engine to return to a normal idle.do you think please something to do with the brake booster??kind regards Paul e nz.
Sounds like an issue with the vacuum pump and/or check valve
