Hi all I have a used verso 2014 and my horn was quite intermittent from last year, just passed MOT. Anyway just recently found the horn completely stopped working. 2 weeks ago I took the car to a random garage, guy opened the bonnet and removed a plastic panel from the front and did something and the horn worked 100%. Although I couldn't see what he did and only took £5.
Just yesterday I noticed the horn stopped working again. Did something possibly become loose where he was tinkering around?
Anyone?
  • 4 weeks later...
ARe you sure its the horn? Look at the thread above this, which tells you the fix if its the push button the steering wheel
So had to remove cover from wheel and clean contracts and it's working again.
https://youtu.be/5E56HAuOK50?si=2nH54ugaEPzujLvA
