Engine oil change
wills777
Hello house, please what engine oil can I use to service my engine Toyota auris hybrid 2010.
83,000 mileage
any engine oil with specs 0w20 A5 , GL-5, GL-6.
Brand as per your choice. I use Petronas since 2016 and it’s a good oil.
https://www.ebay.co.uk/itm/185255002336?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=gt2bXHAaQNG&sssrc=4429486&ssuid=p34UK1z2T4m&var=&widget_ver=artemis&media=COPY
The fluidity of the oil you will put in the car should be 5w30 now for the brands it takes a lot of searching, people here know the above very well. With a little luck and patience you will get relevant information
1 hour ago, TonyHSD said:
Γεια,
οποιοδήποτε λάδι κινητήρα με προδιαγραφές 0w20 A5 , GL-5, GL-6.
Επωνυμία σύμφωνα με την επιλογή σας. Χρησιμοποιώ Petronas από το 2016 και είναι καλό λάδι.
https: EMIS & Media = Αντίγραφο
5w30 can put TonyHSD
The Toyota recommendation is 0W-20.
Extract from the topic below: Mk3 Prius, Prius plug-in, Prius +, Mk1 Auris HSD, Mk2 Auris HSD & Yaris HSD (up to 2020) 0w20
You’re in different regions though so maybe that’s why there’s a discrepancy guys?
Yes, the climate we have here in Greece plays a role, how cool the temperatures are, etc. However, TOUOTA Europe gives specific instructions in the instruction booklets for all of Europe, at least for my car. The parameter of 5 or 0w and to 20w 30w and so on should also be analyzed
