Hi guys I'm looking for a diagram that shows the cable connections from the sensor (by the window) to the steering switch (light switch) and then to the module.
I had a website that showed all of the parts and available diagrams but sadly the website doesn't work anymore.
Thanks in advance!
Hi guys can someone verify if this is correct.
what are you trying to do?
everything connects to the bcm aka ecu-b nothing is directly connected
I have a light sensor that needs to be connected to apparently ECU-b but I cannot find it I need some assistance knowing where it is so I can connect it so when it's night time the headlights turn on automatically.
So when I bought the car it had an auto light switch on the light regulator ( Screenshot2024-02-20at22_33_11.thumb.png.0ac947bdc660b435ea689a8f884c412b.png)  and then noticed that it did not have a light sensor I bought this (Screenshot2024-02-20at22_35_00.thumb.png.2f92c7f8785a645e161e3b90d7662073.png) thinking the cable should have been underneath the dashboard but I could not find anything so I tried to figure out where this sensor needs to be connected to.
Hopefully, I made it a bit understandable 🙂 thanks for your help.
Auto lights - has someone just fitted a stalk if so you will not have any of the wiring in place, none of the control side will be wired either
Drop me a PM with your VIN and I will look it up and see what you have from factory
