1. The car has a lot of scratches on all the disc (on the previous 13-year-old car, I had completely shiny disc, so I don't know whether to solve it or if it's normal)
2. Since I got the car on winter tires and the car also had Dunlop summer tires, I want to sell them and put on all-season Michelin Crossclimate 2
3. I am dealing with security device, I am 90% decided on Pandora Primo. What security device do you have?
4. I solved the dash camera by connecting it from the dimming mirror and connected it to the right side of the window.
5. I ordered a booster from Lidl in case the 12V Battery runs out, I originally ordered from banggood.com, but I've been waiting for a month and nothing. https://www.lidl.sk/p/ultimate-speed-mobilny-startovaci-zdroj-s-powerbankou-umap-12000-c3/p100367517?mktc=shopping&et_uk=a8a9f612c5354d33bf84d78fdc6dd9c8 Do you think it can be?
6. I couldn't figure out why there is an unheated line about 5cm from the top of the glass on the back window when the heating is on - it's because of the FM and AM antenna.
7. Is it normal to have rust directly on the top of the hood lock (eye)? I have it on 1 year-old car.
8. Does anyone know how to set the radio and sound to play in the back? Through infotainment, I set it to play in the middle, but the Speakers only plays in the front. You have it like this too?
Thank you
1. Friction brakes are only used on the final metres of stopping under normal condition, as most of the braking is regenerative and done by the electric motor. Non hybrid cars discs will be shinier than hybrid cars discs.
2. Put on whatever tyres are legal in your country.
3. If it does what you want, go for it.
4. Should really piggyback a hardwire kit to the fuse panel in the footwell.
5. 12v Battery should be OK. I had a 2019 hybrid saloon, and had no 12v problems in my 4 years of ownership. But it's always handy to have a jump pack on standby,
6. You are correct. The unheated lines are aerials. I had to check with my dealer when I had my saloon, as I thought there was a problem.
7. Surface rust can be present on the bonnet catch. The paint is easily worn off when opening and closing the bonnet, and it's forefront when driving in all sorts of weather.
8. You set the speaker balance through the multi-media screen. If you set it to rear and there is no sound, I would surmise that you do not have rear Speakers fitted. You'll have to check if they are there.
