Hi I currently own a 2005 Toyota Corolla 1.4 VVTI, I’ve noticed the car has a lot of body roll and I’m trying to eliminate this via lowering springs or coilovers.
if anyone has a set laying around/for sale please do email me/reply here to let me know.
I am a college student so I am on a pretty tight budget hence coming to the forums😁
If the original shocks, they will be well past it, replacing them with OE ones should improve things dramatically,  you could also replace the springs as they may be equally worn or even broken.
It can be diy job if your have the right equipment, but lethal if not done properly as the spring is under heavy tension, best left to a garage ?
You can buy firmer shocks and springs, but like any such mod from standard spec, they may invalidate your insurance.
