Steering wheel and ECU??
Blaise
I would like to ask you for help please.
I have an Avensis T25 2005 1.8 VVTI.
I had a scary experience with the steering wheel and the computer on board.
At low speed 🥲 sometimes the power steering intermittently goes heavy, then rights itself AND the screen in the middle of the board ( with speed, mileage ... ) goes off for a few
second as well.
I have bought an OBDII device : no error or failure found.
The Battery is OK and I think the charging too ( 12.5 V and 14.4 V )
Thank you very much for reading and if you have any ideas please could you share it.
Sorry for the bad English.
4 hours ago, Blaise said:
second as well.
The battery is OK and I think the charging too ( 12.5 V and 14.4 V )
Is those electric power steering if they are then the electric power steering pump is going out .as this happened to my wife's little VW car and we'll was not cheap I couldn't understand why it went out because I stripped it and it looked like was nothing wrong with it but had to been as I got a new one and working great since unless it's the wires going into the electric power steering pump. Always a pain that when HAPPENDS as it's a expensive fix I like the fan belt power steering pump not the electric one
The 1.8 T25 uses electric PAS I gather. The fact that the centre screen is going off too suggests it might be a voltage drop caused by something relatively simple like corroded Battery terminals or earth strap perhaps?
Thank you very much. I think I have to take it to the local Toyota garage. I do a little mechanic but the electricity is not really my thing. Thank you again.
