Yesterday afternoon after my trip I plugged in the charger as I normally do ready for the pre programmed charge using the car's timer set at 0200  the following morning, at 0022 a message came in on the Toyota mobile app of "interrupted charge" ( 98 mins early) and this morning there had been no recharge. We have had no power cuts and cars info was checked that it would charge Friday 0200  . . . Zilch. Any thoughts out there please?
Only time I've had charging interruptions has been to do with the charge point rather than the car. It's only happened 2 or 3 times in 2.5 years and specifically down to the charge point breaker tripping (appears to have been rectified by dropping the charge output by 0.5kw in the charge point settings).
I presume you have tried plugging in and "charge now" to see if the charge point is working?
Having said that, I've never set the schedule in the car. I control the schedule from the charge point, so if it's a software glitch with the schedule in the car, I wouldn't have seen it.
I have had that happen a couple of times as well. (I normally set charge time via the app, though). No clue why it happened...
It worked perfectly last night so let's hope it was just a one time glitch. It will become annoying if it persists.
