Vehicle Jack on 13reg Hybrid?
Hybrid8
So had a trye blow out the other day.
Car & me are fine, but went to put on space saver wheel & no car jack?
Did the 13reg Yaris Hybrid get issued with one?
As if so someone nicked it?
Replacement bought.
Have a look under the driver's seat for a plastic moulding which covers the jack.
Under front passenger seat.
Assuming its not been nicked, slide the front passenger seat forward, open the rear N/S door and the jack should be visible. Unclip the plastic moulding and loosen the jack out of its metal frame. Same location on Mk2 & Mk3.
If its not there as described, have a wee look in the boot on the righthand side it might be in a removable panel there.
But has the OP found the locking wheel-nut key?
