High Idle
GT-Tyn
Hello, i have a question?
After a trackday on circuit Zandvoort(holland)my idle speed didn't drop to 850 RPM
It's now 1200 RPM.(and on a cold start it is 1700 RPM)
I have a 3sge engine 3e gen.(158 hp)
Can somewone help me ?????? :ffs:
firsly this is the celica forum and you own a carina. from cold a celica spins at 1700 to 2000 rpm , then drops to the 850 mark ,perfectly normal.if its running high now, take off the earth lead or take out the EFI fuses , this should correct the ecu and return to normal.
Yes sorry but there is no carina topic.
And the engine is the same as the celica engine.
i did what you saying ,but no results.
And the ecu didn't give a trouble code!(before resetting)
the timing belt is not jumped a tooth.
I have clean the throttle body ,it was dirty YES,but the problem is still there.
I try to tune up the idle but the adjust screw is already on the bottom(to his end), so i can't get the idle lower with the adjust screw .
And i checked the isc valve but thats good.
And the air intake temp. sensor is also good.
:help::help:
try !Removed! the throttle cable back as far as it will go , my celica idles erratic at times , then some days it runs sweet as can be.
maybe the oxygen sensor has seen its day , mind boggles.
try unplugging the sensors on the throttle body 1 at a time until the revs die down , i think its the cold start thats jammed on or broken ,on mine its the one on the right of 2 ( blue multi plug )
!Removed! hell I’ am very good humored YES!!
And as first i want to thank you ,with sharing
You’re own experience and science !
i have affected the problem, it’s the vacuum valve of the power steering. It's under the engine on the
right side of the car.
i will post under the massage a couple of pictures from the problem i had.
Maybe i can help someone with this in the future, having the same problem's as me.
It cost me a month to find it.......
Here it’s broken
And here it’s fixed
:D
congrats , and arn't you pleased. :yes:
