Brake servo on Yaris hybrid 2014
barnonline
I have a rather strange problem on my Yaris from 2014 TOYOTA YARIS (_P13_) 1.5 Hybrid (NHP130_) (75Hp)
The brake warning lights began to light up on the dashboard.
I could feel no difference on the brakes, -I have not tried to activate the ABS with a hard braking.
The brake fluid level is fine, and it is not leaking.
I took the car to an authorized workshop that told me it was the brake servo that was the culprit and that I would cost me 5600 Euro to get it fixed, and approximately half, if it was a used spare part. That seems excessive.
I had to give that some consideration….
Here comes the strange part: It is only a problem if the temperature is over approximately 5C, if it is colder than that, the lights turn off.
I have confirmed this with many observations, it is 100% certain that it have something to do with the ambient temperature.
This makes me suspect a sensor malfunction. Does anyone have a clue or hint?
Might be a wheel speed sensor. I'd try braking hard to see if ABS activates as it should.
Also, did the garage read any ODB codes? That might give further clues.
You need the exact code to pin point the issue, when was the 12v Battery last changed or is still on its original ?
