Obd code 1604 ,2011 avensis 2.0 d no crank
noggie baby
Hi ,new to the club ! With a problem  !!
Topic moved to the Avensis forum.
what are the symptoms?
Have you had the Battery checked, it may crank but if the voltage drops too low it will make the ecu freak out
when was the fuel filter last changed/drained?
1AD or 2WW engine?
