passenger seat belt and warning sound
thefinest1
hi all
has anyone encountered this? when i switch on the car the seat belt sign flashes. with no one in the passenger seat, it continues to flash. as i move off it then sounds the warning (like the passenger didn't buckle their seat belt) how do i resolve this?
thanks
? Wrong section as your profile says Avensis 2002?
If a Yaris, then have you put anything on the seat, a bag etc?  I've put a laptop bag on the rear seat and it sometimes complains. If the seat is empty, then as a temp fix connect the seat belt and have the dealer take a look (possibly under warranty).
no, nothing on the seat. it just started out of nowhere
make sure there is nothing wedged under the seat and the jack is secure
hi, yes, i just checked for any obstructions. i moved the seat back and forth and checked under the seat to see if there was anything. i also made sure the electric clips were seated in properly. i turned engine on and seat belt sign didn't come on! weird!! i'll have to monitor it
Just put something heavy on the seat when you go for an MOT (M-I-L).
