Interior lights, central locking, radio not work 2010
MimiK
Suddenly all the interior lights, radio/cd player and central locking not working, its a Toyota Yaris 2010 5 door car - took it to the garage to have the fuses checked - he says all is good, but could not find the DOME fuse - I have a main fuse box under bonnet and passage side - i saw the expert use his gadget to check the fuses but then ask a pink fuse - recheck all but still could find DOME - can anyone help or guide please thank you - MK
Go to startmycar.com put Yaris 2010 in search and will show you picture of fuse box and diagram showing location of fuse.
Did you find the solution for this? I have the exact same issue, checked all the fuses with a continuity meter, but they are all good. Would be super helpful to help me solve this annoying issue!
On 2/6/2024 at 9:49 AM, flash22 said:
people get lazy checking fuses and don't pull the fuse to check them or the condition of the socket
Once had a glass filament fuse.  It passed the continuity check but the device would not work.
Holding it up to the light showed a globules of metal half way down.  The conclusion was overheat, melt, then cooled and solidified.
Andy,  change the suspect fuse.  A new fuse may work, just the change process might fix it.
Okay I’ll try this thanks!
