On 3/8/2024 at 10:20 AM, robo1 said:
Yes they are called fixpoint. You replace the cover with one with a hole in it and screw a bolt into the roof connector. If you visit roofbox.co.uk you can put in your car details and view the options including instructions.
not sure why above is blue?
Any idea where to get covers with holes or is it a generic job?
The covers with holes come with the Thule attachments to replace the ‘solid’ original ones used when not using roof rails.
Thank you robo1. I knew I should have gone Thule....😡
1 hour ago, Dm800 said:
Thank you robo1. I knew I should have gone thule..
TBH the covers are not really needed. They’re not waterproof and when you have the bars fitted you cannot see them. If you decided to take the bars off but leave the anchor bolts in the roof then you would see them!
