Number not contact name shown, incoming call
When I get an incoming call, I only see the number on the display, not the contact name. Knowing the contact name would help me decide if I want to take the call or not.
I looked through the phone settings and, to me, looked like it was all configured correctly.
Have you tried removing the +44 to 0, it seems to have worked for a few others.Have you recently had a software update. Did you receive caller id before you had problems. Hope this helps👍
Have a look at this thread. It may help
Thanks for the replies.
I will check the country prefix tomorrow, I seem to recall that all calls on the screen are shown with the country code, but I'll recheck.
I don't know if I've ever had a software update, I've never seen anything of that nature on the screen (car connects to home WiFi when parked on my drive).
OK, I've looked at this today
I tested this with 1 contact, but the principal applies to all. All my contacts are not stored with the country code. If I call my phone (andriod 12) even though the contact is not stored with the country code the country code is displayed when the call is recieved.  There is a feature called assisted dialing (phone > 3dots > settings > assisted dialling) the narrative says "default home country automatically detected" regardless of this setting all incoming calls are prefixed with CC.
This suggests to me, that the issue I am seeing lies with the phone.
Fyi the car settings are: menu > setup > phone > contacts/call history > automatic transfer = on
I will try with another phone, thanks for that suggestion.
I will also take a look at the link supplied.
One forum suggested it might be a network provider setting, but after contacting them, they said it's a handset thing.
Question: when the contacts sync, do I see this on the screen, e.g. a message?
The solution, in my case, was to reset to default the contacts/call history and resync contacts now incoming calls and texts are shown with name and number is preceeded with CC
Glad you resolved the problem it will help others who have experienced the same issue and may help them with this fix.👍
