toyota proace
raymen
hi everyone , any idea could help me .
my toyota proace van tile light is working only one side but breaks, hazard, reverse lights are working fine . i change complete set of light from left to right still not working . both set are fine as i check it only connector or leads problem . is any idea both tail lights has got separated fuse ?
LED or Bulb tail lights ? change the bulb and or check the connector
hi, thanks for reply, i change bulb , but the set works on other side. connector seems ok , as indicator ,breaks and revers working fine .
Proace is a rebadged Stellantis product so not a real Toyota. Check the number plate lights plus the front side / position lights all work correctly.
Also check all the fuses for the lights as they will be more then one fuse.
