Auris MMT Actuators
qwertyking121212
Hi - I have the common issue with the MMT gearbox. Drops into N when I stop and even sometimes when the car is moving. It’s a 2007 1.6 Auris.
3 stages to my repair im thinking…
1/ clutch actuator recondition
2/ gear actuator recondition
3/ clutch replacement (I’ll need the garage to do this is required)
I decided to recondition the Clutch Actuator myself. The bearings on the rod aren’t turning smooth and the brushes in the motors are worn. So I’ll replace these parts.
Should I have put the clutch into “clutch clamp” mode? Or for that matter did I need to do anything before removing the clutch actuator?
And will I need to do anything similar before I remove the gear actuator?
 Of course I’ll initialise using techstream after refitting.
Thanks!
Hiya - just bumping this to see if there any thoughts...
Thanks for the links @flash22. Appreciated.
So I have refurbished the Clutch Actuator - and Initialised + Learnt the clutch using Techstream.
But no joy. The car won't go into gear and stays in Neutral. Error code p0810. But I know that is just the error code - the cause is something I'm trying to work through...
See the attached data readings.
Is there anything obvious I am missing?
Or is next stop the clutch change?
do your brake lights work?
shift motor current looks a bit off
check the shift motor resistance it should be <100 ohms
I take you do not have any trouble codes stored?
the MMT ecu (TCM) outputs for the motors may have died, when you did a relearn could you hear/feel the motors
Hi
Brake lights - I’ll check when I’m back with the car.
Trouble code 0810 is logged.
I did a relearn this morning. I could hear the motors for the actuator and gear actuator.
One thing that felt off was that after the learning is finished - the gear actuator only went through the gears after I turned the ignition off and then on again.
How can I check the shift motor resistance without taking it out? I also presume the shift motor is one of the motors on the gear actuator. (That’s sounds like a silly question - I realise!)
P0810 is a clutch actuator/TCM issue
it's not unusual for some of these reman actuators not to work properly - a new clutch would be the next step
