USB port
Derek coffey
My USB port under dashboard on my Corolla saloon 2019 is not working
Hi Derek,
This is what is recommended to do first. Hope this helps
When the USB port is not working in Your Toyota Corolla the first thing that You should do is check the port for any damage. If any of the pins inside the port are bent or damaged then it will not be able to make a connection to any device that is plugged into it. The next thing to check is the wiring on the back of it. If any of this is loose then it will not work properly since it will not have a proper connection to the head unit. The last thing that You should check is the wiring at the back of the head unit to make sure it is tight and connected well.:smile:
