Aygo mk2 2017
May seem a stupid question, but should my hazard button flash when they are on, or at least light up?
Yes, bulb u/s?
It should, but there are no user serviceable parts inside it, if it's faulty you will need to replace it
Damn, thank you very much😁
The next question is do you need the light?  Can you hear the hazards?  Do both left/right indicators flash?
Yeah, everything works fine.
It illuminates when you turn the lights on, but it doesn't flash as I would expect.
Maybe i am trapped in a timeworn, but I am I have not had a car that the actual button doesn't flash when it is on
Come to think of it, the light in my hazard warning switch does not illuminate. 😞
The switch itself illuminates but when you press the button on for hazards to flash the switch itself doesn,t flash.I use them frequently and noticed this.
Its a 2020 X Trend.
Cheers Paul, then mine is actually working as it should and I won't bother replacing it.
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
