My Corolla is a Toyota Corolla 1.4 Terra MC 5D, 2006, and I installed the oem fog lights into the pre wired plugs, and even put in the indicator stalk with the front fog light, but for some reason they still won’t turn on, can anyone help please.
On our UK spec models, unlike the rear fog lights, the fronts have their own Fuse - FOG 15A and a Relay FOG LP which may be unpopulated on your model ?
Not sure of their physical location, could be in the engine bay fuse /relay box or under the dashboard,  the exact fuse/relay locations usually printed on the boxes covers.
Had this on a '99 Avensis. Thought it would be fit the stalk and the lamps as all the fuses were there & the lamp connectors.
Had to have the full accessory kit as part of the harness was not there.
