Avensis 2011 door lock replacement
Reiniz
Hello! Recently my passengers rear door didn't lock with remote or lock/unlock buttons on driver door, but manually they work fine.
So I have bought 2 used ones already, and they both don't work either. So to rule out wiring issue, I changed it with drivers side rear lock and it works.
My question is have anyone successfully changed door locks it and it works, or you have to go to dealer to program it?
Cant understand if both used locks were broken just like mine or programming needs to be done?
Thanks!
Solved.
So two first locks I bought were cheap ones around 10eur per lock, but decided to try and buy more expensive one around 30eur and its working, was buying from rrr.lt(Lithuanian site), all parts have free returns.
So no programming required, just lock with working electronic motor. Now all doors lock and unlock electronically with remote.
